2007 Suzuki XL7 Brake Lights
43,000 MILES • 6 CYL • AWD • AUTOMATIC
BENGALS54
I have a 2007 Suzuki XL7. One brake light went out and I forgot about it. After a few weeks the other brake light went out. I went to have the bulbs replaced and they said it was not the bulbs, that it was electrical. Everything else works perfectly, but I have no brake lights. My son couldn't find a fuse problem. Of course we couldn't find a fuse marked for the brakes. I just can't see how it is electrical when everything else works. Also the top brake light works on the rear of the car.
Nov 2, 2008 at 12:00 AM
MMPRINCE4000
  • 8,548 POSTS
Check for 12V at the brake light connector. Make sure the lights are grounded and there are no black/burn marks on the housing.
If you have to, pull fuses one at a time and check with a multimeter, until you find a bad one.
Nov 2, 2008 at 12:29 AM
JENNW2NS
I am having the same exact issue with my Suzuki....what was the outcome of your issue?
Oct 18, 2010 at 4:39 AM
PDADDYWHIT
i also have a 2007 XL7 and the drivers side brake light went out and i changed the bulb and it still is not working? don't want to spend tons for an issue that could be done from home?
Dec 13, 2012 at 5:08 AM
