Thermostat Removal and Installation
Removal
Drain coolant and tighten drain plug.
Remove fan shroud with cooling fan after disconnecting radiator inlet hose from radiator.
Remove thermostat cap (1).
Fig. 13: Removing Thermostat Cap
Courtesy of SUZUKI OF AMERICA CORP.
Remove thermostat.
Installation
When positioning thermostat (1) and O-ring on thermostat case, be sure to position it so that air bleed valve (2) comes at match mark (3) and into the recession of thermostat case.
Fig. 14: Positioning Thermostat Properly
Install thermostat cap to thermostat case.
Install cooling fan, fan shroud and connect radiator inlet hose to radiator.
Fill cooling system. Refer to COOLANT DESCRIPTION and COOLING SYSTEM FLUSH AND REFILL.
Connect negative cable at battery.
After installation, check each part for leakage.
Tuesday, April 27th, 2010 AT 4:13 AM
