2008 Suzuki Grand Vitara windowes exchange
2008 SUZUKI VITARA
AMIRFARHAD
2008 Suzuki Grand Vitara 4 cyl Four Wheel Drive Automatic
how to change back door widow.
Dec 19, 2008 at 3:18 AM
DAVE H
  • 13,384 POSTS
Rear Door Glass Removal and Installation
Removal
Remove door trim screw cover (1).
Remove door trim screw (2).
Remove door trim (1).
Remove door sealing cover (1).
Detach rear part of glass run from door sash (1), and remove door sash (1).
Remove door glass (2).
Installation
Reverse removal procedure noting the following instructions.
If there is deformity for glass run, replace it with a new one.
Tighten rear door window mounting screw (a) first and then (b).
Tighten door sash mounting screw and bolts in order of (a), (b) and (c).
Secure door sealing cover (1) with adhesive (2).
Install rear door trim.
Rear door trim attaching order
(1) --> (2) --> (3) --> (4) --> (5) --> (6) --> (7)
Dec 23, 2008 at 1:23 PM
