2006 Suzuki Vitara heater blower
BAGGY62
Heater problem
2006 Suzuki Vitara 4 cyl Four Wheel Drive Manual
Ihave asuzuki grand vitara 1.9 ddis with a broken heater blower. how do I access this.Can you get to it through the engine compartment or does the dashboard have to come off. Thanks for any help
Jan 14, 2010 at 1:07 AM
BAGGY62
to get at the blower remove the clip on panel under tho glovebox. it is only held by 3 screws remove screws pull out the plug and remove the small rubber pipe and thats it. Should take no longer than 10 mins
Jan 16, 2010 at 12:05 AM
SURFY6366
[quote:ed477efcdb="baggy62"]Heater problem
Ihave asuzuki grand vitara 1.9 ddis with a broken heater blower. how do I access this.Can you get to it through the engine compartment or does the dashboard have to come off. Thanks for any help[/quote:ed477efcdb]
Did that help? I just replaced my blower on the exact same model but still won't work.
Surfy
Jan 25, 2010 at 7:51 AM
