2006 Suzuki Grand Vitara FAILED AIR CONDITIONING
2006 SUZUKI VITARA
7,700 MILES • 6 CYL • 4WD • AUTOMATIC
ENDY
I used my car AC in the afternoon when the weather was pretty hot and parked the car. On restarting the car later in the evening I realised that the AC had failed. Looks like the fans are not functioning because if you open the hoot, the AC seems ok but no air comes out from the vents. All the dashboard lightnings seem ok. What could be the problem with the fan, if that is the problem and how can i fix it? Could there be possibly another reason for the failure? Pls help as there is no suzuki shop nearby where i am presently. Thank you.
Mar 4, 2008 at 1:57 AM
DAVE H
  • 13,384 POSTS
start by checking blower motor fuse and relay
Jun 21, 2010 at 7:42 PM
