Heater problems
TABITHASKY
Heater problem 6 cyl Four Wheel Drive Automatic 80,000 miles
My heater works but when I stop the truck at a stop light the heater blows cool air, then I hammer down on the gas and it blows warm air again. I was just wonder what the problem is. I have checked the coolant and it's full
Dec 3, 2008 at 1:20 AM
  • 55,691 POSTS
This sounds like you have a heater core that is plugged, remove both heater hoses and connected a garden hose and turn it on. This should blow any blockage out from it.
Here is a guide that can help as well.
https://www.2carpros.com/articles/car-heater-not-working
Please let us know what you find.
Cheers, Ken
Sep 12, 2017 at 6:19 AM
TRACTORMANBELL
The heater may be leaking, check coolant level, pressure test coolant system if level is low
Sep 13, 2017 at 3:36 AM (Merged)
KHLOW2008
  • 41,812 POSTS
Check above link for more information.
JOHN AND CHRIS
Heater problem
2001 Suzuki Grand Vitara 6 cyl Four Wheel Drive Automatic 120223 miles
my grand vitara does not blow very good heat.
DAVE H
  • 13,383 POSTS
replace thermostat and flush cooling system
