2004 Suzuki Vitara
2004 SUZUKI VITARA
126,000 MILES • 6 CYL • 4WD • AUTOMATIC
HAWFIX
to much fuel consumption
Mar 15, 2010 at 3:56 AM
LEGITIMATE007
  • 5,121 POSTS
is there a check engine light on?
Mar 15, 2010 at 4:23 AM
BMCDOUGAL12345
no
Apr 10, 2010 at 1:19 AM
LEGITIMATE007
  • 5,121 POSTS
ok, then you may just hav some basic things you need to do here, if you havent done plugs and wires, that would be a good start. also I would check fuel pressure just to rule out the fuel pump and filter and pressure regulator as being the culprit. are you experiencing any black smoke? also change your air filter if you havent already, touch bass with with me as to what you've done already
Apr 10, 2010 at 2:05 AM
