2003 Suzuki Vitara Turbocharger gone bad for the 2nd time.
2003 SUZUKI VITARA
129,000 MILES • 4 CYL • 4WD • AUTOMATIC
ROGELIO SANTOS
HI! My vehicle is a 2.0 turbocharged diesel. one month after i buy it, it started to smoke a lot and when i got under the hood i find out that the turbocharger was letting oil into the air intake. Well i replaced it and it worked well. now it has been two weeks since I changed it and it is did the same. But now it is worst. My question is what can cause a turbo charger to go bad so quick? oh and there is a check engine light on the dashboard. When I ran a scan it shows a exhaust waste relay fault, could that have something to do with it?
Apr 19, 2009 at 12:57 PM
AFS
Hello!
Verify the harness and the ground connection of the IAT sensor. Check also the EGR valve. I had this problem and the Suzuki guys in Rio solved it this way.
Jul 28, 2009 at 9:22 AM
