2002 Suzuki Grand Vitara
BOB ARCHIE
  • 2002 SUZUKI VITARA
when I engage 4 wheel drive the light does not come on. I think it could be blown bulb. How do you get at the bulb?
Monday, December 15th, 2008 AT 12:24 AM
DAVE H
  • 13,384 POSTS
INSTRUMENT CLUSTER
Removal & Installation
Disconnect negative battery cable. Deactivate air bag system. See DISABLING & ACTIVATING AIR BAG SYSTEM. Remove knee bolster. Move steering column to lowest position. Remove instrument panel cover screws. Remove instrument panel cover. Remove instrument cluster retaining screws. Pull instrument cluster from dashboard and disconnect any connections. To install, reverse removal procedure.
Tuesday, December 16th, 2008 AT 10:00 PM
