2001 Suzuki Vitara OVERHEATING
2001 SUZUKI VITARA
142,000 MILES • 6 CYL • 4WD • AUTOMATIC
MR0229346
I have a 2001 Suzuki Grand Vitara 4x4. I have changed the water pump, thermostat, sent it to a radiator shop and changed the fan. It keeps overheating and the water of the backflow container keeps flushing out and the truck is burning through a quart of oil within a week. Mechanic says we need to remove the engine to change a gasket but it would be a lil costly to do that and it not be the problem. If you can please tell me of any other possibilities.
Apr 15, 2010 at 7:46 AM
Get it block and pressure tested to rule out the headgasket cracked head or block and intake leak
Apr 15, 2010 at 8:41 AM
