2001 Suzuki Vitara car stalls and is hard to start
2001 SUZUKI VITARA
JEFFTHE
Computer problem
2001 Suzuki Vitara 4 cyl Four Wheel Drive Automatic
we drove this car through a puddle about a month ago and alter that the car would stall when u removed your foot from the gas and would not run if u did not keep your foot atleast gentely on the throttle.. i had it scanned and was told it was the mass air flow so after 400$ later the problem was the same.. i was told th use a good throttle cleener and a tooth brush and cleen the throttle plate and barrel that didnt work so i bent the little arm on the throttle just a little to get the jeep running but i know there is still a problem as fast idle is not working properle and it will still try to stall.. i had it scanned again and got a general code of intake flow system error, that tec told me to tak the assembly bellor the throttle out and cleen it that it was probably that so i did that and no difference.. note that everytime i do do something it does work a little better but not for more than a half houre.. i dont want to spend more money than i need to with this so if there is anything i can try please help??
Oct 28, 2009 at 11:20 AM
DAVE H
  • 13,384 POSTS
the code could be from you bending the part to keep it running .. replace the air filter ans recheck MAF sensor readngs
Jun 27, 2010 at 6:06 AM
