2001 Suzuki Vitara 2001 Suzuki Hard Starts
2001 SUZUKI VITARA
200,000 MILES • 4 CYL • 4WD • AUTOMATIC
LAWMANRUIZ
Hello All,
I've Got a 2001 Suzuki Vitara powered by a G16B engine with automatic trans. Darn thing works well when i get the engine started.
Engine Diagnostnics didn/t turn up anything.
Previous owner 'lived' with this situation . It does not stall /back fire or make trouble noises.
It Hard starts both Cold and Hot , then sometimes starts in a one.
Engine has been tuned up -Hard starts any how.
Anyone got some suggestions?
Thanks and Happy Holidays to you all.
Lawrence
Dec 22, 2009 at 1:29 PM
  • 31,937 POSTS
Hi there, i would be getting an on car injection service, i would also have the ignition check on an oscilloscope, do a comp test, check that the correct spark plugs are fitted, fuel pressure is ok and you have good presser retention, if it is only hard to start after sitting for a few hours, check for fuel pressure retention in the fuel rail, you may have fuel draining back.
mark (mhpautos)
Dec 22, 2009 at 11:34 PM
LAWMANRUIZ
[quote:c33ad7eae8="mhpautos"]Hi there, i would be getting an on car injection service, i would also have the ignition check on an oscilloscope, do a comp test, check that the correct spark plugs are fitted, fuel pressure is ok and you have good presser retention, if it is only hard to start after sitting for a few hours, check for fuel pressure retention in the fuel rail, you may have fuel draining back.
mark (mhpautos)[/quote:c33ad7eae8]
Thanks for your advice
The situation i believe is that the Throttle Body /Idle Air control clearance (which as you know is non adjustable) is buggy. built up the IAC plunger with a bit of epoxy and got it starting in a one -but the idle rpm is to low - i just did this to ascertain that im on the right track- so now the issue is to replace the TB and iac from salvage and see what happens.
By the way thanks for the imput - all the electricals and machanical checked out - scope patterns were good and constant .
I wont recommend the aformentioned (epoxy IAC ) as a repair consideration - ok .
Lawmanruiz
Feb 6, 2010 at 1:59 PM
