2000 Suzuki Vitara TROUBLE SHOOTING
2000 SUZUKI VITARA
270,440 MILES • 4 CYL • 4WD • MANUAL
JENESISBALAGTAS
I HAVE MY SUZUKI VITARA, ENGINE CRANK BUT WOULD NOT START, I PULL OUT THE NOZZLE I NOTICE NO FUEL OUT FROM NOZZLE TIP .I REPLACE NEW FUEL PUMP I CHECK ALL POSSIBLE LAKE GOOD FUEL . BUT NOZZLE LACK OF FUEL NO ? OUT FUEL . UNTIL NOW? GOOD SPARK OUT HIGH TENSION WIRE. WHAT POSSIBLE CAN CAUSE MY VITARA JLX.
May 29, 2010 at 4:24 AM
  • 31,937 POSTS
Hi there,
I would first run a scan and check for any set fault codes in the ECU, report any codes for further assistance.
Mark (mhpautos)
May 29, 2010 at 5:09 AM
JENESISBALAGTAS
I check the ecu I pull out then I test ecu to other suzuki vitara then it run the engine I notice ecu is good . but when return to my unit suzuki vitara it could not start. what possible can cause of my vitara.ecu was good all fuses was also good in relay was new.fuel pump was also new, CDI of my distributor was new.the old cdi was burn. Then I replace a new one. please help my suzuki vitara jlx . thanks ,,......how can I buy a diagnoses harness to detect the possible damage to my suzuki IM. mechanic from Phillipines . NORTH cotabato provines....
Jun 12, 2010 at 6:29 PM
