1999 Suzuki Grand Vitara when should I replace shocks &
1999 SUZUKI VITARA
16,000 MILES • 4 CYL • 2WD • AUTOMATIC
MILLIMAN7
When should I replace shocks & Struts for my 1999 Suzuki Grand Vitara or do I just need balancing and a wheel alignment? There is a slight vibration and a bit of uneven tire wear.
Jul 25, 2008 at 2:38 AM
SERVICE WRITER
  • 9,123 POSTS
IF they are original it would certainly make a difference in your ride. Weak ones will cause an abnormal wear pattern
The vibration may be from the irregular wear or tire balance.
If the uneven wear is edge wear, then it may be from a lack of rotation or an alignment issue.
You can do a bounce test on the four corners of the truck. IF you get a few good jounces on the bumper the truck should recover after one bounce. IF not the struts/shocks are weak.
IF they are leaking excessivley, then replace them.
Jul 25, 2008 at 1:38 PM
