1999 Suzuki Grand Vitara Leaking valve seals causing smoke
1999 SUZUKI VITARA
131,000 MILES • 6 CYL • 4WD • AUTOMATIC
PASAN84
Can you replace the Valve seals without removing the heads?
Dec 27, 2007 at 2:33 PM
BLACKOP555
  • 10,386 POSTS
yes they can be, but you will have to use compressed air in each cylinder to prevent the valves from dropping down into the engine.
Dec 27, 2007 at 2:36 PM
