1996 Suzuki Vitara Heater switch off
1996 SUZUKI VITARA
106,000 MILES • 4 CYL • 4WD • MANUAL
JOHNH42
  • 5 POSTS
Vitara JLX 1.6 - 16v
I cannot switch off the heater.
The air is set to external flow, I slide the hot /cold lever fully over to the left at the cold setting and the air is still warm coming out of all vents, what wwill be the cause and how do I correct this problem please.
Thanks
John
Aug 13, 2010 at 9:42 PM
KHLOW2008
  • 41,814 POSTS
Hi John, Thank you for the donation. There are 3 cables behind the control panel and they are for the mode, heater/cooling and fresh/recirculating air. If the heater is not cutting off, the air mix door is not closing correctly so you need to check the cable adjustment. In the diagram the 2 red arrows indicate the cables that you should check.
https://images.2carpros.com/forum/automotive_pictures/192750_HeaterCables96VitaraFig02a_1.jpg
Place the temperature control lever in HOT position. Place air flow control lever to defrost position. Place air intake control lever to fresh position. Ensure control levers do not move while attaching appropriate cable with cable clip.
Aug 14, 2010 at 12:49 AM
JOHNH42
  • 5 POSTS
Many thanks for your advice, I will check this out tomorrow when it has stopped raining.
Regs
John H
Aug 14, 2010 at 1:20 AM
KHLOW2008
  • 41,814 POSTS
You're welcome.
Keep me posted of the outcome.
Have a nice day.
Aug 14, 2010 at 1:29 AM
JOHNH42
  • 5 POSTS
Thanks guys I found the problem,
the rubber duct from the fan, which is just above the passenger footwell was out of position.
I suspect it had been knocked by a passenger and this was preventing the flap that re directs the airflow from shutting fully.
It now works a treat so problem solved many thanks
John H
Aug 20, 2010 at 4:20 AM
KHLOW2008
  • 41,814 POSTS
You're welcome and glad to know you have fixed your problem.
Have a nice day.
Aug 20, 2010 at 6:20 AM
