1992 Suzuki Grand Vitara shifter pulled out
1992 SUZUKI VITARA
S-TEVE
Transmission problem
1992 Suzuki Grand Vitara 4 cyl Two Wheel Drive Manual
the tranmission shifter pulled out of the transmission. The transmission is hard to get into reverse most of the time.
There is a spring under the boot. What holds the shifter in to the trans?
Jun 16, 2008 at 10:41 PM
MDEMETZ
On my '02 Tracker, on the shifter there is a cup with slots which fits over the 2 bolts that project into the shifter hole. The spring hold tension on this cup to keep it from unlatching. My spring has broke, so sometimes the cup comes loose,
Jun 17, 2008 at 1:57 PM
