1990 Suzuki Vitara
SHARON97
Engine Performance problem
1990 Suzuki Vitara Manual
Hi, This does not happen all the time, but the car starts fine, if a little high but being an H reg im not surprised by this, I can drive for about 10 minutes and sometimes when i start to slow down the engine gets a litltle jumpy, and whent the acceleator is pressed down there is very little power. I have to put the clutch down to stop it from stalling. On the last few occasions however the car has stalled and takes a few times to restart and even then will not run for long. The car feels like it needs a cought to clear the system. I have used the injector/radion cleaner and I am unsure if this help and I did this 1 week ago and had the problem again.
Feb 14, 2009 at 10:55 PM
2CARPRO JACK
  • 11,533 POSTS
Has it been tuned up with OE (original equipment) parts? If tune up is good, you may have a sticky/leaking injector.Have the computer scanned for codes, this may lead to the cyinder that is causing the misfire.
Feb 15, 2009 at 12:21 AM
SHARON97
Hi, unsure if it has been tuned! Would this be a big and expensive job, the tax is due this month?
Feb 15, 2009 at 12:27 AM
2CARPRO JACK
  • 11,533 POSTS
A few hundred dollars.I would do it asap
Feb 15, 2009 at 2:23 AM
