2004 Suzuki Verona Heater
2004 SUZUKI VERONA
24,000 MILES • 4 CYL • FWD • AUTOMATIC
CLAUDE12
The heater does not blow hot. When you adjust the temp. knob on the dash nothing happens. The heater hoses get hot but you get no hot air in car.
I pulled the glove box out and the linkage on the what i believe to be the heater door operator tries to move when you turn the temp. knob. If you help the linkage the least bit it will go ahead and move. Once it moves you can operte the knob slightly and the linkage moves as it should. If you ever turn the knob all the way back to cold then you have to help the linkage move again to get the heater to blow hot air. did not tear down any further. Need advice.
Jan 13, 2008 at 8:22 AM
DAVE H
  • 13,384 POSTS
Temperature Cable Removal and Installation
NOTE:Because the cable and the cable housings have fixed lengths, it is impossible to make a temperature cable adjustment.
Remove the glove box.
If a malfunction is suspected, verify the proper operation of the controller and the mechanical doors for the heater/air distributor case assembly.
Removal
Disconnect the negative battery cable.
The heater/air distribution case linkage also cannot be adjusted.
Disconnect the cable retainer from the blower housing.
Slide the cable eyelet off the post on the temperature door lever.
Fig. 20: Sliding Cable Eyelet Off Post On Temperature Door Lever
Courtesy of SUZUKI OF AMERICA CORP.
Remove the audio system trim plate. Refer to INSTRUMENT CLUSTER TRIM PANEL REMOVAL .
Remove the four controller retaining screws.
Pull out the controller to provide clearance for removal of the temperature control cable.
Disconnect the temperature control cable eyelet from the post on the controller.
Snap the cable housing connector out of the slide position on the controller.
Fig. 21: Snapping Cable Housing Connector Out Of Slide Position On Controller
Installation
Install the temperature control cable eyelet to the post on the controller.
Snap the cable housing connector to the slide position on the controller.
Fig. 22: Snapping Cable Housing Connector To Slide Position On Controller
Gently insert the controller into position on the center console.
Install the four controller retaining screws.
Tighten the controller retaining screws to 4 N.m (35 lb-in).
Install the temperature control cable eyelet to the post on the temperature door lever.
Snap the cable retainer to the blower housing.
Fig. 23: Snapping Cable Retainer To Blower Housing
Move the temperature control to verify the smooth operation and function of the door and the cable.
Install the instrument cluster trim panel. Refer to INSTRUMENT CLUSTER TRIM PANEL INSTALLATION .
Connect the negative battery cable.
Operate the heating and cooling systems to verify proper function.
Install the glove box. Refer to GLOVE BOX INSTALLATION .
Apr 21, 2010 at 9:10 PM
