2004 Suzuki Verona heat/ac fan slows down as I drive
RAINER386
Heater problem
2004 Suzuki Verona Automatic 55,000 miles
The heat/AC fan in my car usually starts running okay if it has been sitting overnight, but as I drive it slows down to where it almost comes to a complete stop. If I restart the car during the day (after a few hours or so), the fan never starts up. I am still getting warm air in the car.
Apr 14, 2008 at 12:37 AM
DAVE H
  • 13,383 POSTS
Blower Resistor Removal
Disconnect the negative battery cable.
Remove the glove box. Refer to GLOVE BOX REMOVAL .
Remove the footwell upper cover. Refer to INSTRUMENT PANEL REMOVAL .
Disconnect the electrical connector at the resistor.
Remove the mount screws from the resistor.
Remove the resistor from the heater/air distributor case by gently pulling the resistor downward.
Apr 21, 2010 at 9:18 PM
