2004 Suzuki Verona Diagnostic codes
CNROBERSON
2004 Suzuki Verona
I had problems when driving yesterday as far as when I switched from reverse to drive it felt like the engine was going to fall out from under the hood then while in drive the car acted like it was in an off gear. Check engine light came on and I had the diagnostic test done. Auto Zone pulled codes P0700, P1672 and P 1673 off but could not pull anything up for a Verona. Can anyone tell me what these codes mean? Thank you very much.
Mar 21, 2010 at 4:44 AM
DAVE H
  • 13,383 POSTS
DTC P1672: CAN Bus Off Failure
Fig. 152: DTC P1672: CAN Bus Off Failure - Diagnostic Wiring Diagram
Courtesy of SUZUKI OF AMERICA CORP.
Circuit Description
The transaxle control module (TCM) is an electronic device which monitors inputs to control various transaxle functions including shift quality and transaxle sensors, switches, and components to process for use within its' control program. Based on this input information, the TCM controls various transaxle output functions and devices.
Information is transmitted between the TCM and ECM through the CAN. Information is as follows:
Engine Malfunction Signal.
Engine Speed.
Engine Output Torque Reduction Signal.
Engine Coolant Temperature.
Conditions for Setting the DTC
System voltage is too high or too low.
CAN transmitting wiring harness shortage or open.
TCM or ECM is defective.
Immediately after the above condition occurs.
Action Taken When the DTC Sets
The malfunction indicator lamp (MIL) will illuminate.
The TCM will record operating conditions at the time the diagnostic fails. This information will be stored in the Failure Records buffer.
Adopt Emergency/ Substitute mode and constant 4th gear by hydraulic control.
After ignition OFF/ON: 3rd gear by hydraulic control. Possible P, R and N also possible.
Conditions for Clearing the MIL/DTC
The MIL will turn OFF when the malfunction has not occurred after three-ignition cycles.
A history DTC will clear after 40 consecutive warm up cycles without a fault.
Using a scan tool can clear history DTCs.
Fig. 153: DTC P1672: CAN Bus Off Failure Diagnostic Chart
DTC P1673: CAN Receive ECM Message Failure
Fig. 154: DTC P1673: CAN Receive ECM Message Failure - Diagnostic Wiring Diagram
Circuit Description
Engine Speed.
Apr 29, 2010 at 10:28 PM
