2009 Suzuki Swift Is water to be Added on coolant?
GLOBALTRUCKDEALER
Engine Cooling problem
2009 Suzuki Swift 4 cyl Two Wheel Drive 22 miles
Suzuki swift with DDIS 4 cylinder diesel engine, there should be added water in coolant or just plain coolant need to add.
if the water has to be added then in what ratio it should be added??
Oct 28, 2010 at 9:55 PM
  • 31,937 POSTS
Hi there,
This will depend on the type of coolant used, most are 50/50 but a water top up is not a problem, if you have a coolant loss problem, fix it drain and flush and use fresh coolant.
mark (mhpautos)
Oct 28, 2010 at 9:59 PM
