2008 Suzuki Swift ABS FAULTY
5,289 MILES • 4 CYL • FWD • MANUAL
PANADOL
  • 16 POSTS
ABS warning light keep on.i already change the wheel speed sensor,driveshaft,ABS control module,wire harness.But the light still on.the faulty is (C1026 wheel speed sensor performance malfunction LF).i ready clear the trouble code .warning light will go off.But when i travel more then 2km or 5-10 min.The warning light will come on again.trouble code is the same....
Aug 25, 2009 at 11:39 PM
DAVE H
  • 13,383 POSTS
if you have any special type wheel rims this could throw off the readings ?
May 29, 2010 at 10:53 PM
