2007 Suzuki Swift key coding
17,000 MILES • 4 CYL • 2WD • AUTOMATIC
GOVIND
how we can make suzuki swift car model 2007 made for japanese market chassis model ZC71S
ACCEPT one virgin smart keys
we have one transponder key shell
May 15, 2010 at 12:34 AM
DAVE H
  • 13,383 POSTS
Immobilizer Programming Procedure
Turn the ignition switch to the ON position.
Install the scan tool.
Select IMMOBILIZER PROGRAMMING FUNCTION from the BODY menu.
Follow the scan tool instructions with each key until all keys are programmed.
Cycle the ignition 3 times as indicated by the scan tool.
Turn the ignition to the LOCK position, disconnect the scan tool and test all the keys.
If any key does not function, perform this procedure again with all keys.
If any key does not accept the programming, replace it with a new key and perform this procedure again with all the keys.
May 29, 2010 at 10:44 PM
RAINGER007
Dear sir,,
my suzuki model is 2010 but i have lost my key ...i want to help me someone ....i can't drive my car without the key and no one key expert here to solve this problem....now i am facing with this problem....plz give me a advise for this problem.
i am waiting your reply sir,,,plz help me
Mar 9, 2013 at 12:40 AM
