engine check lamp always on.very high fuel waste.
so i went to garage,mechanic use a engine scanner for check the fault.but scanner screen show,"connection failure".the mechanic not able to find out what is the problem.pls give some idea,to find out these fault.
Feb 7, 2009 at 4:33 PM
