2002 Suzuki Swift engine check
79,000 MILES • 4 CYL • FWD • AUTOMATIC
AUTOPLUS
engine check lamp always on.very high fuel waste.
so i went to garage,mechanic use a engine scanner for check the fault.but scanner screen show,"connection failure".the mechanic not able to find out what is the problem.pls give some idea,to find out these fault.
Feb 7, 2009 at 4:33 PM
DAVE H
  • 13,383 POSTS
try another service centre or a dealer to retrieve the fault codes !! you could try removing and carefully cleaning the MAF sensor .. but you would still need a diagnostic computer to verify where the fault lies and turn off the light
Apr 28, 2009 at 2:37 AM
