1997 Suzuki Swift Fuel Pump
SCPARKER82
Engine Mechanical problem
1997 Suzuki Swift 4 cyl Automatic
Where is the fuel pump located in a 1997 suzuki swift hatchback? Do you have to drop the tank to replace it?
Jun 23, 2009 at 1:18 PM
OBXAUTOMEDIC
  • 3,719 POSTS
Yes, the pump is in the tank and I believe you will have to drop the tank to replace it. You can check under the flooring in the back for an access if the tank is mounted under the back, check under the back seat if the tank is mounted midship.
Jun 23, 2009 at 2:08 PM
CHEADY
u can skip looking under the seat.....
Jan 16, 2010 at 3:31 PM
