1995 Suzuki Swift fan belt
SUZUKI
Noises problem
1995 Suzuki Swift V8 Manual
I only got my car a few days ago, the first time i took it out yestaday half way through a short journey it sounded like something had fallen off ! I stopped and checked but everything appeard fine. Today when i started the car it makes a horrible rattling noise. Iv had a look under the bonnet and a belt has fallen off ! (im sure its the fan belt as the battery light is on to). But should it be making this awfull noise if it is just the belt ?
thanks
Vikki
Aug 4, 2009 at 8:49 PM
  • 31,937 POSTS
Hi there,
There should not be any noises like that, with out hearing the noise it is a bit hard to come to a conclusion, so i would have the belt replaced and get a mechanic to check all the pulleys and bearings as something is failing, get this done asap.
mark (mhpautos)
Aug 4, 2009 at 10:43 PM
