1991 Suzuki Swift zero compression
TANYAWEBSTER
Engine Mechanical problem
1991 Suzuki Swift 4 cyl Front Wheel Drive Manual
My Swift has spark, has fuel, timing belt turns, camshaft moving, zero compression, won't start. Could the timing belt be out of time? or could my problem lie in a sensor?
Apr 27, 2009 at 2:54 PM
DAVE H
  • 13,383 POSTS
Do you have zero compression on all cylinders ? did the belt snap or has it jumped teeth ?? Even if the timing was out you would still get compression at some stage in the engine cycle ... it's definately not a sensor !!
let me know
Apr 28, 2009 at 2:34 AM
TANYAWEBSTER
I have zero compression on all cylinders. The timing belt is in one piece and spinning. It ran like a dream, then one day just stalled and wouldn't start again.
Apr 28, 2009 at 2:40 AM
DAVE H
  • 13,383 POSTS
Check all the teeth on the belt are intact (no gaps) not stripped anywhere... I suspect the belt may have jumped some teeth on the camshaft (is it tight)and maybe bent valves ... if you have no compression on ALL cylinders you must have a bad valve in each one ... or your piston rings in every cylinder have gone bad .. but all at the same time ?? you are going to need to strip the engine down to locate the fault i'm afraid ? let me know
https://images.2carpros.com/forum/automotive_pictures/266999_AAA2_599.png
Apr 28, 2009 at 2:55 AM
