1991 Suzuki Swift
29,000 MILES • 4 CYL • FWD • MANUAL
KDX_GREEN
I drove the car home Sunday night and it ran fine. Monday morning it started and ran for thirty seconds then died. Now it will only start if you hold the throttle wide open. It will start then the engine will labor until it reaches about 2,500 rpms then it will run fine as long as you keep the rpms up. As soon as you let them down it will start to labor again until the rpms come up again.
Dec 25, 2009 at 9:01 AM
  • 75,988 POSTS
Check and test the coolant temperature sensor, airflow sensor,MAP sensor and TPS to include the idle speed control solenoid
Dec 25, 2009 at 9:28 AM
