1997 Suzuki Sidekick vibration
GODFROIE
  • 1997 SUZUKI SIDEKICK
  • 4 CYL
  • 4WD
  • 100,000 MILES
I have a vibration that come from under my sidekick I tried changing the driveshaft, the wheel bearings, I change the tire and wheels, but it is the same, when it is on two wheel drive it vribrate, but when I put it on 4 wheel drive the vibration stop, where should I look for tthe problem. Thanks.
Monday, March 1st, 2010 AT 8:51 PM
KHLOW2008
  • 41,814 POSTS
Hi godfroie,
Thank you for the donation.
When does the vibration occurs?
During acceleration only?
After attaining a certain speed?
The driveshaft you mentioned replacing, were they the front CV or the propeller shaft?
Wednesday, March 3rd, 2010 AT 1:19 PM
GODFROIE
The vibration when I am on two wheel drive occurs during acceleration and as the speed increase the virbration get worst, at 60mph the vibration is terrible. When I put it on 4 wheel drive the vibration is not there, except when I slow down from 60 to 50 then there is a little vivration.
I change the rear driveshat. Thank you very much
Wednesday, March 3rd, 2010 AT 1:52 PM
KHLOW2008
  • 41,814 POSTS
The symptoms seems to indicate a fault with the propeller shaft.
The most likely cause soule be bad U joints. Get them checked for wear or stiffness.
Thursday, March 4th, 2010 AT 9:28 AM
