Transfer case jumps out four wheel drive high to two wheel lock hubs are checked and replaced not sure why it doing this.
Jan 23, 2017 at 10:40 AM
HMAC300
✓Experienced Mechanic
lock hubs only lock the wheels not transfer case. check for wear of shifter as it may not be going into gear all the way. Otherwise it is either a bent shift fork or shift sleeve inside the transfer case.
Jan 23, 2017 at 10:26 PM
LEN23
MEMBER
Only once up to speed it jumps out.
Jan 24, 2017 at 5:28 AM
HMAC300
it still can be what I said. make sure it is full of fluid.
Jan 24, 2017 at 7:04 AM
LEN23
MEMBER
Transfer case is full of fluid.
Jan 24, 2017 at 7:33 AM
HMAC300
then the tcase will have to come apart to find problem.
Jan 24, 2017 at 8:30 AM
LEN23
MEMBER
Jumps out of four wheel drive once get out of speed. check transfer case shifter light on the dash does lock in. Check cable linkages.
Jan 27, 2017 at 7:40 PM
(Merged)
LEN23
MEMBER
It werid it finally good now it seem fixed it self
Feb 10, 2017 at 5:51 AM
It might start happening again which I would agree with HMAC300 on a transfer case problem.
Please let us know happens so it will help others.
Best, Ken
Feb 13, 2017 at 3:15 AM
LEN23
MEMBER
I found out the one tire had different tread pattern. Also unbalanced tire causing it to jump out
Nov 29, 2018 at 9:34 PM
Glad you could get it fixed, that kind of problem can be tough. Please use 2CarPros anytime we are here to help
