1995 Suzuki Sidekick cutting out above 4000 rpms
1995 SUZUKI SIDEKICK
ERICHOOPES
Engine Performance problem
1995 Suzuki Sidekick 4 cyl Four Wheel Drive Manual
all of a sudden my rig just started not running and cutting out at above 3500rpms.. it was fine before this... it has good power up until about 3000rpms??
Feb 16, 2010 at 3:57 PM
Inspect and test all the following listed below:
Oxygen sensors.
Catalytic converter.
Fuel injectors dirty/sticking.
Mass airflow sensor/Airflow meter.
Throttle position sensor.
Manifold absolute pressure sensor.
EGR Valve
Fuel pressure regulator leaking or defective fuel pump.
False air leakage.
Fuel contamination.
Foul/defective spark plugs.
Open spark plug wires.
Ignition coil/Coil packs defective.
Incorrect ignition timing.
Cap and rotor.
Note:If it doesn't apply disregard
Feb 16, 2010 at 11:11 PM
