1994 Suzuki Sidekick F-1 fuse blows
180,500 MILES • 4 CYL • 4WD • AUTOMATIC
SHOCKME123
ive tried changing relay, , also lowered fuel tank, changed fuel-filter, checked connections for loose grounds , or shorted wires, , tried removing one at a time the fuel injector- electrical connections , , did find a loose wire in fuse panel, tap wire to the F-1 and relay clicks, so i could use some help , cant aford to take it to a shop, have tools and need some guidenss. thanks guys
Feb 1, 2010 at 1:37 PM
DAVE H
  • 13,383 POSTS
re solder the loose connection !
Mar 15, 2010 at 12:53 AM
