1989 Suzuki Sidekick missing.....
BOBBYD3423
Engine Mechanical problem
1989 Suzuki Sidekick 4 cyl Four Wheel Drive Manual 125k miles
I recently picked up this 91 Suzuki Sidekick. The guy i bought it from was having trouble getting it running right. After a little research i found that the motor is actually a 1.3l witch they only put in these trucks in 89. Obviously there has been a motor swap at some time. My problem is that i am gettin good spark on the #2 cylinder but when its running and i disconnect the plug wire nothing changes. All the others when disconnected make the motor stumble and almost die. Its running like crap and right now its the only vehicle i have. What can i do?
Jan 1, 2010 at 7:40 AM
DAVE H
  • 13,383 POSTS
check the #2 plug is good !
Apr 23, 2010 at 9:48 PM
