1988 Suzuki Samurai high initial cols start idle
JOHN OAKMAN
Engine Mechanical problem
1988 Suzuki Samurai 4 cyl Four Wheel Drive Manual 55k miles
initial cold start idle speed 3000 rpm as engine warms the idle speed comes down to normal,but the initial 2800-3000rpm is worrisome. I have cleaned the choke with spray cleaner and my mechanic says all the flaps-ports are working.
I have had the vehicle since new and the starting sequence use to be: cold start initial rpm about 1000 then increasing to 2000 as the engine warmed and then a drop back to normal.
Thanks for your service
Mar 22, 2009 at 3:48 AM
KHLOW2008
  • 41,812 POSTS
Hi John, Thank you for the donation. Seems the fast idle is out of specs and here are the procedures for adjustment.
https://images.2carpros.com/forum/automotive_pictures/192750_FastIdleAdjust88SuzukiSamurai_1.jpg
https://images.2carpros.com/forum/automotive_pictures/192750_FastIdleAdjust88SuzukiSamurai01_1.jpg
https://images.2carpros.com/forum/automotive_pictures/192750_FastIdleAdjust88SuzukiSamurai02_1.jpg
Mar 24, 2009 at 5:35 AM
