2006 Suzuki Reno
AHOSKIN
Transmission problem
2006 Suzuki Reno 4 cyl Front Wheel Drive Automatic
were would you find the fill hole for the transmission, car doesn't have a dip stick
Mar 10, 2010 at 7:22 AM
DAVE H
  • 13,383 POSTS
Transaxle Fluid Level Checking Procedure
Tools Required:
DW260-070 Transaxle Fluid Plug Remover/Installer
Start the engine and allow the engine to idle for approximately 5 minutes, or, if possible, drive the vehicle for a few kilometers (miles) to warm the transaxle fluid. Check the fluid level when the transaxle is over 30 °C (86 °F).
Fig. 85: Identifying Transaxle Fluid Plug
Courtesy of SUZUKI OF AMERICA CORP.
Press the brake pedal and move the shift lever through the gear ranges, pausing a few seconds in each range. Return the shift lever to the park position. (Left-Hand Drive Shown, Right-Hand Drive Similar.)
Fig. 86: Identifying Shift Lever Gear Ranges
Raise and suitably support the vehicle.
Place a fluid container below the fluid level plug.
Remove the fluid level plug using the plug remover/installer DW260-070. Because the transaxle operates correctly over a range of levels, fluid may or may not drain out of the plug hole when the plug is removed.
Fig. 87: Identifying Plug Remover/Installer DW260-070
Check the oil fluid level. If fluid does not drain through the plug hole after adding a total of 4 liters, then the transaxle was either underfilled or the transaxle is leaking fluid. Inspect the transaxle for fluid leaks. Fix any leaks before setting the transaxle fluid level.
Fig. 88: [Adding Transaxle Fluid]
Install the fluid level plug using the plug remover/installer DW260-070.
Tighten:
Tighten the Fluid Level Plug to 45 N.m (33 lb-ft).
When the fluid level checking procedure is completed, wipe any fluid from the transaxle case with a rag or shop towel. Also, check that the fluid fill cap and the vent tube are properly installed.
Apr 29, 2010 at 10:34 PM
