Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Suzuki
Reno
Engine
Camshaft
Camshaft Sensor
2005 Suzuki Reno camshaft position sensor
2005 SUZUKI RENO
31,000 MILES • 4 CYL • FWD • AUTOMATIC
ZURAB
MEMBER
1 POST
what means ciruit bank low signal ?
Mar 30, 2009 at 6:54 AM
BLUELIGHTNIN6
Experienced Mechanic
Indicates an issue with the sensor wiring or the sensor itself. Most common it is the sensor that is failing which will cause this code.
Thanks for using 2CarPros.com!
Mar 30, 2009 at 6:59 AM
Add image or video
Ask a new question
Check engine light
Air Conditioner — Not Working
