2005 Suzuki Reno camshaft position sensor
2005 SUZUKI RENO
31,000 MILES • 4 CYL • FWD • AUTOMATIC
ZURAB
what means ciruit bank low signal ?
Mar 30, 2009 at 6:54 AM
BLUELIGHTNIN6
  • 16,542 POSTS
Indicates an issue with the sensor wiring or the sensor itself. Most common it is the sensor that is failing which will cause this code.
Thanks for using 2CarPros.com!
Mar 30, 2009 at 6:59 AM
