2002 Suzuki Aerio Rear Fender Rub
SUZUKI
DFORMAN
I bought a 2002 suzuki aerio with aftermarket wheels that were too wide. they rub the rear fender wells when i hit a bump. is there anything that i could do to make the springs stiffer? i dont want to cut the car or change the wheels if i can help it.
Oct 28, 2007 at 1:54 PM
BLACKOP555
  • 10,386 POSTS
yes you can make them stiffer, but you have to get new shocks and leaf's made for heavier loads or offroad. or you could put in a lift kit
Oct 28, 2007 at 2:02 PM
Suggested Repair
Fit heavier-load or off-road shocks and springs, or install a lift kit, to reduce rear fender rub from the wide wheels without cutting the body or changing the wheels.
Conversation Summary
The owner of a 2002 Suzuki Aerio has wide aftermarket wheels that rub the rear fender wells over bumps and wants stiffer springs without cutting the car or changing the wheels. The expert said stiffer suspension is possible with heavier-load or off-road shocks and springs, or with a lift kit.
