1991 Suzuki Sidekick Fuel Pump Cuts Out
SUZUKI
BLEUFROG2
  • 6 POSTS
I've been having fuel relay power being cut off after less the 3 sec, My understanding is that the ecm supply the first 3 sec signal for power then the relay takes it's signal after the distributor ignitor is sending the ok to the ecm.
Is that and ecm or igniter problem ??? Anone knows ? :roll:
Aug 7, 2006 at 6:53 AM
MIKEYBDMAN
  • 623 POSTS
[quote:284288453b="bleufrog2"]I've been having fuel relay power being cut off after less the 3 sec, My understanding is that the ecm supply the first 3 sec signal for power then the relay takes it's signal after the distributor ignitor is sending the ok to the ecm.
Is that and ecm or igniter problem ??? Anone knows ? :roll:[/quote:284288453b]
Need to know what make and model car you have along with year and engine.
Aug 7, 2006 at 7:18 AM
BLEUFROG2
  • 6 POSTS
My ride is a Suzuki Sidekick 91 1.6 8valve
Aug 7, 2006 at 9:41 AM
MIKEYBDMAN
  • 623 POSTS
[quote:6656ecfb39="bleufrog2"]My ride is a Suzuki Sidekick 91 1.6 8valve[/quote:6656ecfb39]
ECM controls ON/OFF operation of the fuel pump by turning it ON via the fuel pump relay under any of the following condition.
-For 3 seconds after ignition switch ON.
-While cranking engine (while engine start signal is inputted to ECM).
-While CAS signal is inputted to ECM.
So with that being said, it sounds like the first 3 seconds is working fine. But no power in the start mode leads me to belive there may be a problem with the engine start signal. Check pin B11 on the PCM to see if you receive 6-10 volts with the starter engaged. This is used for the start signal. If the ECM is getting that signal, but not running the fuel pump, it is probably bad.
Have you tried to supply power to the pump circuit and get the car started? This would eliminate the CAS crank angle sensor which supplies the signal while running.
Aug 7, 2006 at 10:11 AM
BLEUFROG2
  • 6 POSTS
To answer you question, if I put gas in the car directly the truck's engine start no problem. Could you indicte to me where the pcm is located. Is it in the distriutor ?
Aug 7, 2006 at 11:00 AM
MIKEYBDMAN
  • 623 POSTS
[quote:409784d26e="bleufrog2"]To answer you question, if I put gas in the car directly the truck's engine start no problem. Could you indicte to me where the pcm is located. Is it in the distriutor ?[/quote:409784d26e]
This is called a ECM Engine Control Module and it is located under the left dash. If you remove the left speaker cover by your knee, you should see the ECM attached to the fuse box. On the end there are two connectors that should be labled A and B.
Aug 7, 2006 at 11:35 AM
BLEUFROG2
  • 6 POSTS
[quote:060c932ae3="bleufrog2"]To answer you question, if I put gas in the carburator directly the truck's engine start no problem. Could you indicte to me where the pcm is located. Is it in the distriutor ?[/quote:060c932ae3]
I was told there is a plug in the engine compartment that can be use to test the fule pump " I did not find it yet" I have cleaned all the grounds . I guess my next step is to put power to the fuel pump to make sure it's ok, Tomorrow I am returning the ECM I got at the local car recycler he will give me an other one so I'll be able to test it cause last week when I pluged in the replacement ecm the truck worked for about 2 hours, but I really want to find the source of the problem which cause the ecm to fail in the first place. I was also thinking to grap a spare distributor and replace it to make sure it's not the ignitor which is causing the fault . Thanks for all your help
Bleu
MIKEYBDMAN
  • 623 POSTS
[quote:626b9a5653="bleufrog2"][quote:626b9a5653="bleufrog2"]To answer you question, if I put gas in the carburator directly the truck's engine start no problem. Could you indicte to me where the pcm is located. Is it in the distriutor ?[/quote:626b9a5653]
Bleu[/quote:626b9a5653]
I thought you said the fuel pump ran for 3 seconds when you turned the switch on? If you remove the fuel cap, and listen in the tank when you turn the ignition to the on position, you should hear the pump run for 3 seconds. You can also feel the fuel return line behind the filter and feel the pressure on the return line. If both of these tests are good, then your pump works fine. If the trcuk runs fine when you get it started, then the pump is fine. It just sounds liek you are not getting good fuel pressure during start.
Aug 7, 2006 at 11:45 AM
BLEUFROG2
  • 6 POSTS
Well after many hours of painstiking checks. I end up replacing the ecm , the sidekick ran for about 2 hrs than died again, same symptomes etc. I finally figured out the problem is the fuel pump which is intermintent. Sometime it works sometime it s not.
I have ordered a new fuel pump and still waiting to install it. In the interim i purchased some info to bypass the positive side of the ECM which should allow the fuel pump to work regardless of the ECM state. I have implement the bypass , which basically consist of tapping a wire between the ignition coil
black with brown spot wire to the red wire of the connector located in front of the carb , the plug in that goes to the injector. if you unplug this connector turn the key on *without cranking* and check for 12vlt with a test light on the red wire at the connector. If you got no power then the ECM is at fault other wise the problem lies somewhere else. So now I am waiting for the new fuel pump to see the end result of all this work.
Aug 29, 2006 at 1:02 AM
Suggested Repair
Confirm the fuel pump runs about 3 seconds with the ignition on and that fuel pressure is present during cranking. Check the engine-start signal at ECM connector pin B11 for 6-10 volts with the starter engaged; the ECM is under the left dash by the fuse box. If the pump is intermittent, replace the fuel pump rather than assuming the ECM or ignitor is the cause.
Conversation Summary
A 1991 Suzuki Sidekick 1.6 lost fuel-pump relay power after the initial ignition-on prime. The expert explained that the ECM should power the pump for about 3 seconds after key-on, while cranking when it receives the start signal, and while a crank-angle signal is present. Suggested checks included pin B11 for 6-10 volts during cranking and listening or feeling for pump prime and return-line pressure. The owner later found the pump itself was intermittent and ordered a replacement.
