front right wheel shakes
SUZUKI
TKDKALEL
1987 suzuki samurai
manual
4-wheel drive
193,000 miles
The front passenger side wheel shakes at about 55 or when i hit a bump... it stops when i brake a little. it was doin this before i had repairs to itfor the same problem.... a mechanic put a steering box, new shock, rotated the tires, and alligned it. the problem got a little better but there is still a little shake (nothing like the death wobble i had before) and i am afraid it will get worse, because before that is how it started out. With a little shake. What ealse can i check.
May 19, 2007 at 4:53 AM
MIKE H R
  • 3,094 POSTS
have the rims checked to see if one is bent, check the wheel balance. does the car gerab when you put on the brake?
May 19, 2007 at 7:41 AM
TKDKALEL
i have had all that checked and nothing was wrong.
May 20, 2007 at 7:17 AM
