I have no low beam lights?
2005 SUZUKI
45,000 MILES • 4 CYL • FWD • AUTOMATIC
RAUGESON
I have no low beam lights.High beams and parking lights work. When I push the switch ahead for low beams, they go completly out. Bulbs, fuses, relay good. Replaced light switch on steering colume. This is a 2005 Forenza.
Dec 4, 2007 at 8:37 PM
DAVE H
  • 13,383 POSTS
check wiring and ground connections
Apr 29, 2010 at 10:42 PM
  • 55,809 POSTS
If the other lights work it sounds like the headlight switch itself is bad, here is the headlight wiring diagrams so you can see how the system works and I have included how to change the switch out as well. Check out the images (below). Please let us know what happens.
Jul 1, 2024 at 6:14 AM
