2004 Other Suzuki ignis Timing chain
2004 SUZUKI
TAMARA LAWSON
2004 Other Suzuki Models 4 cyl Front Wheel Drive 99000 kms
just need to know when to replace a timing chain, and should it require maintenance if it doesn't need replacing? My engine is a bit noisy.
Jan 2, 2009 at 2:15 PM
KHLOW2008
  • 41,812 POSTS
Hi tamara lawson,
The is no scheduled timing chain replacement. If and when the chain becomes noisy, it is time to replace it. It is a maintenence free item.
Usually a bad timing chain would rattle loudly when starting from cold and the noise would lessen once the oil pressure in engine builds up.
Jan 4, 2009 at 1:49 AM
