2000 Other Suzuki Models engine stall when driving
2000 SUZUKI
IAN CLAIRE
Engine Performance problem
2000 Other Suzuki Models 4 cyl Two Wheel Drive Automatic
what are the probable causes of my egine trouble?beacause my engine stalls while driving.it only take about 3 to 5 minutes to run and then the engine stall.
Aug 18, 2009 at 7:46 PM
KHLOW2008
  • 41,814 POSTS
Hi Ian,
What is the model of your vehicle?
Is the Check Engine light showing?
Are you able to keep the engine from stalling by applying throttle pressure?
Did this happen after any repairs?
What is the idling speed when it does not stall?
Aug 18, 2009 at 8:48 PM
IAN CLAIRE
it is a suzuki mini van type,it has 3 cylinders and a E.F.I enigine,its is a second hand car,it has no check light engine beacause it is a oild model van,the engine still shut down even if i put a pressure on the throttle,this is the first trouble after i bought it.what am i going to do?
ian,
Aug 19, 2009 at 6:56 PM
KHLOW2008
  • 41,814 POSTS
You listed the year as 2000, is that correct?
EFI engined vehicles would normally have a self diagnostic terminal. It has been a long time since I last handled such a vehicle and my assistance would be limited.
I will check through and see if I can come up with anything on this.
In the meantime, you can browse through the link below and see if you can come up with anything.
https://www.2carpros.com/kpages/first_things.htm
When engne stalls, are you able to restart?
Aug 20, 2009 at 2:12 AM
IAN CLAIRE
i read the the link that you give me and its a big help for me i find out what the reason is,i find out that my fuel filter is full of dirt after i clean the tank and the change the filter the car now is back to normal.and also red the manual of my car it is a suzuki super carry 2004 model minivan.once again thank for helping me.
truly yours,
ian claire
Aug 21, 2009 at 12:05 PM
KHLOW2008
  • 41,814 POSTS
You are welcomed and glad to be of service.
Anytime you got a question, you know where we are.
Have a nice day :)
Aug 22, 2009 at 2:43 AM
IAN CLAIRE
good day to all of you,i have another problem,my auntie have a problem on her car,and she consult me,her car is mitshubishi lancer GLxi 1996 model,ECI MULTI engine,the problem is when she turn on the key the the check engine indicator will apear and when she starts it the check engine will disapear after a few minutes around 2 to 4 minutes the check ingine will apear again until she shut off the engine,even if the car is running the check engine is still there,i dont where i gonna start checking it,what is the probable cause of this?what is the first thing i will do on tihis?how do i fix it?hope you can help me on this.
truly yours,
ian claire
Aug 23, 2009 at 2:33 PM
KHLOW2008
  • 41,814 POSTS
When the CHECK engine light is showing, an error has been detected in the engine management system and you would have to retrieve the trouble code to know what is causing it.
Most parts stores provides the scaning services frre, get it done and let me know the exact trouble code.
If you refer to the link provided in previous post, you would be able to find a link that explains the Check Engine Light.
https://www.2carpros.com/dia/how_to_scan_trouble_codes.htm
Aug 24, 2009 at 1:09 AM
