1998 Suzuki uneven brake pad wear
1998 SUZUKI
137,000 MILES • 4 CYL • FWD • AUTOMATIC
LEFTUNCHECKD
Driver side front disc brake
The inside pad shows normal wear on top half of pad
and almost no wear on the bottom half.
The strange thing is the outside pad shows even wear both top and bottom.
Do I replace the caliper or the bracket or add a shim
or bleed the line ?
Thanks
Never mind, I fixed it.
Dec 3, 2007 at 1:37 PM
DAVE H
  • 13,383 POSTS
clean and check for free movement on the caliper and piston !
Apr 8, 2009 at 2:22 AM
