1998 Other Suzuki Models my sidekick turns but will not star
1998 SUZUKI
160,000 MILES • 4 CYL • 4WD • MANUAL
MACBEST
Hi there, i was driving my sidekick JX 16 valv 5 speed yesterday and at a street corner it stalled... i cranked it until the battery went dead. I got a boost and it started well... today the same thing hapened 2 times. the first time it started after another boost, the second time it did not want to start. Minutes before the fatal stall, a strong smell (The kind of i got the time i blew my subwoofer speeker) filled the vehicule. What can it be ? Thanks in advance !
Apr 6, 2008 at 5:43 PM
  • 75,988 POSTS
Try below
Get a carb cleaner and spray into the carb or the throttle body on an EFI. Did it start and die? If not disconnect a sparkplug wire or 2 and ground it to the engine -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel problem, check the fuel pressure to rule out the fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light.
Fuel pump and Injector/s checks out-start checking the ignition system-power to coil, coil/s itself,distributor pick-up,control module, Cam and Crankshaft sensors.
If both fuel and spark is present-check the valve and ignition timing, this will lead you to problems with compression and valves opening and closing at the wrong time
Apr 7, 2008 at 3:04 AM
