1998 Other Suzuki Models Headlights
1998 SUZUKI
INJNUITY
Electrical problem
1998 Other Suzuki Models 4 cyl Front Wheel Drive Manual
Safety headlights work fine, High beams for both work ,too. but regular low beams, when sefety not engaged or turned to beam on setting will not work. Checked all fuses and wire paths, all checked ok.
What else could be causing this problem?
Nov 8, 2008 at 8:16 AM
KICK-FIX
  • 29 POSTS
what car, model , what country?
lighting is diff in all countries.
ok sounds like DRL to me.
there are many inputs to DRL.
one is parking brake, if brake switch sticks on this will
cause DRL to fail. ( it think yours is ok)
DRL = Safety? i think so.
you need the DRL schematic for you exact model.
give car spec and country and answer get way way better.
cheers.
Sep 3, 2009 at 6:27 AM
