1998 Other Suzuki Models back brakes
1998 SUZUKI
10,000 MILES • 4 CYL • FWD • AUTOMATIC
HYLA
i have the pads on but cant get anything else back on for some reason can you help? its an esteem
Feb 20, 2008 at 6:12 AM
DAVE H
  • 13,383 POSTS
FRONT DISC BRAKE PADS
Removal & Installation
Raise and support vehicle. Remove caliper pin bolts. Remove caliper from caliper carrier and suspend with wire. Remove brake pads and anti-rattle clips. To install, reverse removal procedure. Bleed brake system (if necessary).
FRONT DISC BRAKE CALIPER
Raise and support vehicle. Remove front wheel. Remove caliper pin bolts. Remove caliper from caliper carrier. Disconnect brake flexhose. Plug all line openings. To install, reverse removal procedure. Bleed brake system.
Mar 25, 2009 at 1:50 PM
