1996 Other Suzuki Models AC problem
1996 SUZUKI
198,000 MILES • 4 CYL • 2WD • AUTOMATIC
ESUZUKI08
Air Conitioner button light will not turn on. Blows hot air, even when freeon was added.
Jun 17, 2008 at 1:05 AM
  • CAR REPAIR CONTRIBUTOR
  • 31,937 POSTS
Hi there,
first check the A/C fuse. If this is ok, you should have the system pressures tested, as this is the first diagnostic test that should be done, just adding refrigerant may only compound your problem, have a tech check the system pressures first.
mark (mhpautos)
Jun 17, 2008 at 4:45 AM
